| code 34 is a detonation sensor code, why would you change your o2 sensors for that? It is the knock sensor itself or the harness for it. code 11 is the crank angle sensor circuit. Check that the connection is clean. Code 13 is the coolant temp. sensor. Check its connection and the sensor itself to see if the metal part is clean. I would just replace it if you never have before. Take the car to someone who knows what they are doing. There are a lot more things you can do but I don't really feel like typing them all out for you. The injectors are probably fine. I don't know what happened to the straw, I would take the intake manifold off and see. Just don't drop any bolts or nuts in it while you're at it.
